04-23-2018 11:44 AM - edited 01-04-2022 04:09 PM
i have been with public mobile for years but recently switch to koodo but now want to switch back
04-23-2018 03:34 PM
@baffour12-abat wrote:so what do i do to get my services back
@baffour12-abat, you have to start right from ground zero like what you did the first time you joined this service. Go pick up a SIM card, activate it, select the desired plan, obtain a temporary number to get the service up and running. Once everything is confirmed to be working perfectly, go back to the self servce account and complete a number port the old service.
04-23-2018 03:11 PM
04-23-2018 03:09 PM
What do you mean back? Is your account in suspension or it just stopped working or...?
04-23-2018 03:07 PM
how can i get my service back
04-23-2018 01:42 PM
Should have been same service since both carriers use same network. I remember when I was with Bell and I switched to Rogers and I did not get the service that I was promised to be given. I learned from my mistake and would not switch to another carrier without giving a second thought. Welcome back and PM isn't bad at all in terms of the prices
04-23-2018 01:21 PM
@baffour12-abat, yes, the service provided by both carriers is on the Telus and Bell shared natioinal network. Service should be almost the same, with minor exceptions (if any)
04-23-2018 12:05 PM
Strange! My mother and brother got a better service when they switched.
04-23-2018 12:01 PM
i was told i will be getting the same services as public but not
04-23-2018 11:55 AM
@baffour12-abat wrote:i have been with public mobile for years but recently switch to koodo but now want to switch back
Just get a new SIM, activate it, then port back your number if you wish. https://www.publicmobile.ca/en/on/get-started
Remember to give one of your friend's the referral so they can save $1/30 days. Right now you will also receive a $10 credit. https://productioncommunity.publicmobile.ca/t5/Announcements/Sharing-is-Caring-Refer-a-Friend-and-th...
04-23-2018 11:46 AM
What you did not like about Koodo?
