03-12-2024 04:13 PM
Hello,
How does one contact technical support, if your having problems with your service etc.? I do not see any technical support tabs to click on and send a message.
Thanks
03-12-2024 04:35 PM
Thank You
03-12-2024 04:28 PM
Thank you.
03-12-2024 04:25 PM - edited 03-12-2024 04:31 PM
Just click on the Chatbot and type in Submit a Ticket to a CS_Agent.
It is faster for this Community to help you if it is a common issue so can we help?
03-12-2024 04:19 PM
@mckinley2 Here’s how to
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
