01-25-2026
11:20 PM
02-22-2026
06:16 PM
computergeek541
trying to port my number in from rogers for the new 20% off deal. I keep getting that error "subscription not activated" at the final stage. I had Public Mobile 2 years ago so I should be considered new activation. is it the issue that I am returning customer and may not qualify or what's the other reason? thanks.
Should I rather select a new number and then transfer a number? Help out please. thanks in advance!
01-25-2026 11:24 PM
@JJ_88 Even returning customer you can get the 50% off deal it’s for all new activations regardless , not sure it would matter if you locked temp first or not public mobile been having issues with new activations this weekend but not everyone having issues . But if you end up needing solid the wait time will be longer than normal right now . But should you need support
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
01-25-2026 11:22 PM - edited 01-25-2026 11:23 PM
hi @JJ_88
reboot phone and try login app again
you can try to see if the PM esim is already installed on your phone if you use eSIM, make sure eSIM is enabled and set as Primary
if you have physical sim, insert it and test
and you can also ask Pm support agent to help.
you can submit ticket by direct message:
