subscription change
Anca
Hi , I want to change my subscription to 6GB, $23.
It is not offered to switch it from my current one
@Anca
We are all members like you and there are no PM staff on this Community so it is up to you if you want to switch to another carrier. Remember they might charge you activation fee and SIM card.
@Anca
That's how Public Mobile operates now. There are other options for plans if they suit you but if your set on the $23/6 GB plan then you're out of luck. If you'd like to switch you can port out to a different service provider.
@Anca
we used to be able to change to whichever plans we want...both upgrade or downgrade...but now Public Mobile just won't allow us to downgrade substantially from our current plan. We can upgrade whenever we want though ...just can't downgrade.
Anca
So basically you invite me to switch to another provider, because this will happen if you don't allow me to downgrade
@Anca  Sorry if you don’t see it in your account to change to you can get it , plans are targeted and not many options to downgrade plan price just upgrade plan price . So I’m guessing you already lay more then $23 now and that’s why you don’t see the $23 plan available to you
TheSterlinger
@Anca
Public Mobile moderates what plans customers can change to. If you do not see it in your account when you sign in you will not be able to have that plan.
