submit ticket fail
cheryl66
failed to submit a ticket. Error message at the top but I cannot find any problem. All fields were filled out correctly.
2 REPLIES 2
CSA_PM
Customer Support Agent
Hi @ cheryl66
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
slusagm
 Since you were not able to open the preferred Chatbot ticket.  So, you will need to message them here:
And share your question, maybe we can help
