11-27-2019 03:01 PM - edited 01-05-2022 08:10 AM
i ordered a the $10 "triple punch" sim card and only received a single micro card. my phone is an LG G5 and it uses a nano card. what do i do now?
Joining Public
11-27-2019 09:55 PM
I have cut several SIM cards down from full size to nano size. Use a nano card to trace onto the full size with a pencil. Cut with scissors. Either I got lucky or it isn't as difficult to get it right as I was led to believe. Just an FYI.
AE_Collector
11-27-2019 03:10 PM
Forget about my previous reply i read it kinda backwards
Many stores have the punch knife, they may have to look in the back, make them go
My brother cut it with the precision knife, but he has steady hand you can ruin it. He used the old card, pressed against it and just carved it out
11-27-2019 03:08 PM
thank you so much for the solution. i just noticed the instructions we covered up by the mailing label.
11-27-2019 03:07 PM
Can you take a picture, didn't show the number though
Where are you located?
The adapters are a buck
11-27-2019 03:06 PM
You could try taking it to a phone repair store to see if they could cut it. Did you order from PM ? If you did then you could submit a ticket to a moderator to request a new sim. Click on the question mark on the bottom right.
11-27-2019 03:04 PM
@jamesd you could click on the question mark on the right hand side of the page and send a message to the Moderator_Team. If you need a Sim card right away you can go to a Walmart, mobile shop or London drug!
11-27-2019 03:04 PM - edited 11-27-2019 03:05 PM
