sim card
06-26-2015 05:51 PM - edited 01-04-2022 01:42 PM
06-28-2015 01:16 PM
06-28-2015 10:49 AM
ok cool he bought phone from them then they closed up shop but he is not getting service but code ieme or whatever ty very much for all your help how do i mark this as answered 🙂
06-28-2015 10:47 AM
Do what @DK said. Go to calm Kiosk or repair shop ask to have them punch the sim card. Try going into Telus or Koodo, they may do it for you.
06-28-2015 10:45 AM
06-28-2015 10:42 AM
he got large and needs micro huge size diff how can we contact them
06-28-2015 10:34 AM
What I usually do after cutting is just take a nail file and very lightly smooth the edges on the top side of the sim. (opposite the metal side)
06-28-2015 10:08 AM
What size did he get and what size did he need??
He can either have it punched if too big. Or order an adapter from eBay if it's too small. I'd recommend that for now, a quick fix.
But I'd definitely use the Contact Us page and order a replacement.
Cheers!
06-28-2015 09:56 AM
my son recieved 1 that was wrong 1 what can he do to correct it
06-27-2015 12:47 PM
At this moment, please note that Public Mobile is currently in BETA. They are temporarily accepting new customers only by invitation.
New customers must join the BETA phase at http://publicmobile.ca/en/on/beta
You will be contacted by email within a few weeks. Once you receive your invitation code, you will be able to subscribe on Public Mobile and order a free of charge SIM card.
For now, there is no faster way to subscribe on Public Mobile. They are in BETA to make sure everything works perfectly before the official launch.
06-27-2015 08:23 AM
If satisfied please mark the answer as solved for future members who may have the same question.
06-26-2015 09:57 PM
On behalf of the above responder, you're welcome, and welcome to Public Mobile!
06-26-2015 09:35 PM
ahh got it tyvm
06-26-2015 05:56 PM
Public Mobile is in Beta meaning that they are limiting the number of SIM cards they hand out. The only way to obtain one is to sign up with your email to be a Beta tester essentially and in roughly 3 weeks or greater you will get an email stating you've been welcomed to join the beta project and you can contact public mobile with a unique pin to have them mail you a sim card free of charge
