04-25-2017 04:31 PM - edited 01-04-2022 01:42 PM
Does anyone know if the 3gb dta plan is 3 for the 3 month period or 3 each month?.
Thx
07-06-2017 01:27 AM
@Bry wrote:
What happens if I go over my data for the month? How much is the rate if I go over 200mb if I don't purchase the add on?
You can't go over. The data just stops working.
07-05-2017 11:03 PM
04-25-2017 05:27 PM
Thanks
04-25-2017 04:35 PM
its 3gb data over the 3 months. So be wise with your data mangement! (90 day plan) So if you use all of it in the first month, you need to buy more data
04-25-2017 04:35 PM - edited 04-25-2017 04:36 PM
If you chose 3GB on 90 days plan then it is for the whole 90 days.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
