sim card doesn't work
cathy_mcd
Hi,
How long does it take to get a message back from the support team?
Thanks
2 REPLIES 2
@cathy_mcd usually within 2 hours
was it a physical sim or eSIM?
what error you got?
if physical, try putting it on another phone , or at least try to reesat the sim with a reboot
HALIMACS
@cathy_mcd
usually it’s anywhere from 30 minutes to a couple of hours
If it’s been longer than four hours, submit another ticket for support
To contact a Customer Support Agent, there are 2 methods: ( use option #2 )
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
