03-23-2020 02:44 PM - edited 01-05-2022 10:03 AM
How can i log into self-serve if i forgot password and answer to my security question?
03-23-2020 03:34 PM
@Kyrablue1984 wrote:I can’t sign into self service it says my email is wrong but I tried every email I could have used
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
03-23-2020 03:33 PM
03-23-2020 03:00 PM
If you don't find it, here's how to get moderator help...
Good luck.
03-23-2020 02:59 PM
I have to spend some time going through my papers to find it.
03-23-2020 02:54 PM
@Pky02 wrote:Thanks
Looks like you have a Solution...what did you do to get in to your account ? Did you remember the question ?
03-23-2020 02:54 PM
Checking
03-23-2020 02:53 PM
Thanks I'll try
03-23-2020 02:52 PM
Thanks
03-23-2020 02:50 PM
Thanks, I tried but it didn't work
03-23-2020 02:47 PM - edited 03-23-2020 02:50 PM
Password is your email address...does that help ?
Edit...ignore...the Username is your email address. Did you write down the password somewhere ? Did you keep the Welcome to Public Mobile email ?
03-23-2020 02:47 PM - edited 03-23-2020 02:47 PM
@Pky02 You have to contact the moderators directly through private message here. Ask them for a reset password link.
Keep an eye on the envelope top right of your screen. The mods answer will show up there.
