sign in without verification code
jcfortin
ca i sign in simply
jcfortin
you should say security at login
hairbag1
You can...just log in to your account and disable the 2FA security feature.
@jcfortin yes, you might
You just need to login to My Account once using 2FA code, then go to Profile Page and there is the security setting and you can disable 2FA.  But make sure you aware it is not as safe
