service not working
11-19-2022 09:14 AM
Hello Team,
In my account, I can see
Add-Ons
11-19-2022 03:06 PM
@hitesht youbare callomg it daily?? maybe you used up the LD minutes? Again, use Incognito mode to login to My Account to confirm if the addon minutes are still there.
If not, buy the appropriate addon depends on where you calling. There are different LD addons and you need to buy the right one
11-19-2022 02:01 PM
Adding to what @softech said above, unfortunately you'll need to buy another add-on to call outside of Canada.
https://www.publicmobile.ca/en/bc/get-help/articles/overview-of-add-ons
Choose the one that corresponds to the country you'd like to call.
11-19-2022 10:05 AM
yes, I am using that number on daily basis
11-19-2022 10:04 AM
I'm trying to call outside Canada. If I'm not wrong long-distance minutes can be used to call outside and I am in Canada.
11-19-2022 09:16 AM - edited 11-19-2022 09:17 AM
@hitesht "When I am trying to make a long-distance" .. were you still calling within Canada? The 500 Canada wide Long distance minutes are only used for calling within Canada
And try to use Incognito mode to confirm the minutes are correct (without Incognito mode, you might be reading off old cached info)
If you are sure you have the minutes, try to reboot the phone once and make the call manually and remember to put in 1 in front of the 10 digits phone number
11-19-2022 09:15 AM
@hitesht , what you are describing are the add-ons in the account. In order to use those your account has to be in active status. Does your account show as active?
