self serve registration
Dale3
keeps resending me a six digit number everytime i enter they send me a new one
1 REPLY 1
HALIMACS
That is most strange, @Dale3
Do you mean every time you log into your self-serve, or are you in the process of setting up your self-serve account?
If 'setting it up', it's possible if refreshing or exceeding certain time-limits, another code is being sent?
EDIT:  If you're experiencing continued issues, recommendation might be to wait an hour, then clear cache and cookies, open incognito tab, and try again.
If problem recurs and you can't proceed, contact the moderators (PM customer service) to describe situation.
To contact a moderator, send a private message to the moderator by clicking here
