05-24-2019 04:22 PM - edited 01-05-2022 05:04 AM
Hı !
I whant to know if the samsung a10 work whit public mobile.
The cell information are:
- GPRS/E: 850/900/1800/1900, 3G: 850/900/AWS/1900, LTE: B1/B2/B3/B4/B5/B7/B8/B12/B17/B20/B38/B40/B41
The phone are very new so it not listed on willmyphonework.net.
Thanks a lot!
Phones
05-24-2019 06:33 PM
@Morak wrote:the internet is not very important for me ( lte, 3g ect...) I whant to be sure its ok for calling!
thanks to help me
You've received plenty of answers here. According to gsmarena, it should work fine for voice. It has one band for LTE.
Samsung Galaxy A10 India shows the two main voice bands and also just the one LTE band.
05-24-2019 05:55 PM
thanks to help me
05-24-2019 05:12 PM - edited 05-24-2019 05:23 PM
05-24-2019 05:05 PM
1700 uplink are not mentioned so....?!?!
05-24-2019 04:49 PM - edited 05-24-2019 05:16 PM
@Morak wrote:its the international version
but i dont find the a10 on telus and on willmyphonework.com
Public Mobile utilizes the following frequency bands: 4G LTE and LTE Advanced
700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS)
HSPA
850 MHz and 1900 MHz (UMTS)
And a10 have:
I think all its ok for PM but I whant to be sure before to buy it!
05-24-2019 04:37 PM
05-24-2019 04:36 PM
HSPA
And a10 have:
05-24-2019 04:28 PM - edited 05-24-2019 04:29 PM
You can also check telus mobility website. If it's listed as one of their phones available for their plans, then it will also work on PM. Just make sure the version you get is not the international version.
05-24-2019 04:25 PM - edited 05-24-2019 04:27 PM
@Morak wrote:Hı !
Thanks a lot!
@Morak That phone will work with PM without any issues.
Note: Public Mobile has partnered with willmyphonework.net as the new compatibility checker.If you can’t find your make and/ or model, provide feedback directly here.
05-24-2019 04:25 PM
@Morak wrote:Hı !
Thanks a lot!
Good job! Someone will tell you shortly! You always will have more answers and help here in the english forum!
