roaming
Carlnod66
I live on Campobello Island. For the past week I can't make phone calls. System says I don't have us roaming. I don't need us roaming, I'm in Canada.
2 REPLIES 2
@Carlnod66  - try turning off Roaming on your device.
Tap the Airplane mode switch to turn on or off. Turn on / off data roaming From the Home screen, swipe up on an empty spot to open the Appstray. Tap Settings>Connections > Mobile networks.
Tap the Data roaming switch to off.
If you ever travel to the USA, you will just need to turn this back on.
dust2dust
You will need to turn off automatic network selection and choose Public. Your phone is picking up US towers better than Public (Telus/Bell) towers.
