referral for Public mobile, but didnt see in my account se
Yellyell_C
My friend as a new user for Public mobile. She used my referral to open account. BUT ,one month past and I didn't see in my reward yet.
CSA_PM
Customer Support Agent
Hello @ Yellyell_C,
Your friend needs to open a ticket, and an agent can check if the code was applied during activation. They will need your referral code, phone number, and your name.
Sydney8
This happened to me then after about a week it showed up in my account. Maybe check the rewards tab on the app
@Yellyell_C
The $10 referral credit should only take up to 72 hours to to be added into her account. Also you should have gotten a message from PM indicating "Cha-Ching! You just added to your Refer a Friend Reward. Keep referring to earn more. Your 1 point/month will be at at your renewal date.
The referral code is a mix of 6 letters and numbers and not your PIN.
No worries, she will need to contact by dm a CS_Agent indicating it was a mistake.
Yellyell_C
She used my pin to start registration for new account.
