referral code not working?
Scypher0th
trying to activate a friends sim and im inputting my referral code and its not doing anything in the app....literally nothing....how do i know if it is working? when i go to checkout there is no sign of my referral code
@Scypher0th   as long as you copied and entered it during activation , it should work
after activaton, wait 72 hours, check your friend's MyAccount and should see the $10 there.  If not, have your friend to message support and they can add it back
@Scypher0th  Do you not see a green check mark once you enter it
Scypher0th
i type in my refferal code hit apply and nothing....screen stays at it is and all it gives me if the option to cancel.
