11-22-2019 05:17 PM - edited 01-05-2022 09:47 AM
i have recharged my phone yesterday but now no minutes availablke and i have not called anyone. Why this is happening and there is no call center so that we can call and ask i am feeling cheated by the company .
11-24-2019 09:36 AM
I know this won't solve your issue, but it might get you through until you get up and running. There's an app called fongo. It gives you free calling while on wifi. You'll have a different number on that connection but it will allow you to call.
I have an account just in case. It may benefit you in the future, whereever you go especially if you have a limited minutes plan.
If you decide to stay, make sure you purchase the $5 for 500 minute add on. It's the best value on the public mobile site. Minutes only expire when you use all your plan minutes and then the 500.
11-24-2019 09:27 AM
i am not able to call from 15 and now its 24. i only know how i am managing
11-24-2019 09:23 AM
@katewapoonam4 you are correct. We have to be able to help each other here. You can always send a support ticket but it takes time. @CS_Agent will fix it for you if you like.
Creating a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
11-24-2019 09:18 AM
i have done that on 15 nov.
no ill not chnage now. ill chnage the company now . these guys doesnot have anything from where we can call and talk to them
11-24-2019 09:14 AM
What did you change your plan from and to?
Did you ask for it to change now or at next renewal?
11-24-2019 09:11 AM
no this is the first time . i changed my plan bt didnot made any calls so how can 100 minutes finished?
11-22-2019 05:39 PM - edited 11-22-2019 05:43 PM
By the way, if you put $15 on your account and this is not your renewal date, it should still be there. You can use that money to purchase the $5 addon.
Buying an add on is a two step process. Add $$, then purchase add on
11-22-2019 05:33 PM - edited 11-22-2019 05:40 PM
OK, but was yesterday your renewal day, OR had you run out of minutes so you added $15 to your account?
If this is the case, you cannot renew the same plan early. Another option would be to add $5 to your account and buy the $5 for 500 minute add on. This will get you through to your next renewal and the minutes never expire until you use them.
So, if this happens again, you'll be protected then too.
11-22-2019 05:30 PM
The plan is of $15 and with tax its $17 and yesterday only i have recharged it. Now i am going to change my company
11-22-2019 05:26 PM - edited 11-22-2019 05:26 PM
What plan are you on?
When was your last Renewal date?
11-22-2019 05:25 PM - edited 11-22-2019 05:27 PM
The quick fix, is to send a ticket to @CS_Agent.
But if you do some research, you may find your answer quicker.
Moderator Hours
