05-03-2019 11:35 AM - edited 01-05-2022 07:23 AM
05-03-2019 11:38 AM
@Dfg54357 Assuming you are asking how to get 1 GB extra, you need buy an add-on which will cost you $30 and it will not expire until you fully consume it. It might be a good idea to renew early by contacting the mods.
05-03-2019 11:37 AM
when your data runs out, you have 3 options:
- message mods to renew your plan early
- buy the data addon which expires only when it is used up
- do an immediate plan change if you are willing lose your current plan.
