puk
07-01-2020 12:01 AM - edited 01-05-2022 11:55 AM
my new phone is asking for pin and i dont know where to find it. i see that several people have asked the same question but no solution provided??
Joining Public
07-01-2020 09:09 AM - edited 07-01-2020 09:12 AM
@kevinmccaskie sim network unlock pin means your phone is locked to the provider that you got the phone from. (Bell,Rogers,etc)
You would have to contact that provider and ask for the unlock code.
If it's a Samsung phone you can go to Samsung Canada website and open a live chat with them for the code. Below is link for Samsung live chat.
07-01-2020 09:06 AM
SIM network unlock PIN
you then have a choice UNLOCK or DISMISS
07-01-2020 06:07 AM
@kevinmccaskie it sounds like its locked to you previous provider, ask them to unlock it for you. You will need your imei number dial dial *#06# to get it. If its a Samsung phone contact Samsung online and ask them to unlock it for you. Welcome to the community. Stay safe.
07-01-2020 01:13 AM
If you've entered your PIN incorrectly 3 times, you will be asked to provide a PUK. Is this the case for you?
07-01-2020 12:12 AM
Here is a post from @Luddite from another thread.
@paulwooz What is the message?
The following should help to delineate the various PIN messages that can occur:
"SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. As noted by @Triguy Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted by submitting a ticket at: https://publicmobile.ca.ada.support/chat/
Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
07-01-2020 12:07 AM
@kevinmccaskieif you need puk code, check out this similar post here
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/PUK-Number/m-p/529719
07-01-2020 12:03 AM
@kevinmccaskie wrote:my new phone is asking for pin and i dont know where to find it. i see that several people have asked the same question but no solution provided??
What is the exact on screen messsage?
PIN and PUK are different codes.
There are also different types of those codes. Any answer anyone gives you now would be a guess.
