private message delete button not working
zlocksca
Is anyone else having a problem that when trying to delete a private message having a error message: "Authentication Failed" and also not be able to click on a another message
JL9
Whenever you're get that anywhere on the website or in your self serve, a good percentage of the time it will just be a browser issue.
zlocksca
Chromium works as well
@zlocksca   I tried Chrome and Edge and they both work.
zlocksca
Thank you @softech Firefox on Raspbian does not seem to work with the Community for some reason
in both normal or Incognito/Private Mode
@zlocksca   just tried myself and was working without problem.
Try to use another browser, or Incognito Mode  and see if it makes a difference
