posts
12-13-2021 05:47 PM - edited 01-04-2022 04:57 AM
posted some items. want to continue with my subjects. how does this site open my past posts for me to refer to them
Joining Public
12-13-2021 07:51 PM
I usually check the bell icon top right corner beside the mail icon. if a user has replied to my posts, that's where I check
12-13-2021 05:52 PM
your posts PublicGoat's Posts - Community (publicmobile.ca)
or if you want to post new go Browse community > Getting Started > Ask your question
12-13-2021 05:51 PM
@PublicGoat what you meant to be exact?
you can check your profile and you see the items you posted:
you can of course reply on your own post or copy the URL as referece
12-13-2021 05:50 PM
@PublicGoat wrote:posted some items. want to continue with my subjects. how does this site open my past posts for me to refer to them
@PublicGoat Click your avatar, then My Profile and your posts should be listed there...
