porting
teebear
I am having troubles porting my number. i can make calls and it shows my old number but i cant receive calls
MacMe
It can take a few hours for the port to be completed.  But you can try any or all of the following steps:
-Go into your phone's Cellular Network settings and manually select Public Mobile as your Network Operator
-Reboot your phone
-Power off your phone and remove the SIM.  Re-insert and power on
JL9
What plan do you have?
mimmo
if its been more than a couple hours you have a stuck port.  your old sim should however work.  follow instuctions beolow to get help.
How can you get help with your account, activation, or service?
In your message please include:
  • PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue
If you have a Porting issue, please also include:
  • The number you want to port, PM sim number, old account number, old account name exacly as on bill
Don't know your pin?--provide any 3 of the following:
  • Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date & amount
How long until they reply?:
  • Office Hours: Mon-Fri 9am to 9pm, and Sat-Sun 9am to 7:30pm [Totonto Time] from 9am to 7:30pm [Totonto Time].
  • Messages are replied to during business hours and in the order they are received
  • Typical response time is between 1-3 hours, depending on message queue, but can be up to 48 hours.
  • There is no need to send multiple messages.
Additional Useful Information:
  • Search PM-GUIDE (remove "-" during the search) to find some informative posts and answers to many common questions about Public Mobile
