01-31-2026 02:19 PM
did the request a few hours ago, someone was to call us with account issues
01-31-2026 10:32 PM
@Tinabali wrote:did the request a few hours ago, someone was to call us with account issues
The text message saying that somebody will contact you isn't accurate. If you're waiting for somebody to call you about this porting issue, that doesn't usually happen.
01-31-2026 02:36 PM
01-31-2026 02:27 PM
There are two options. There is a number you can call that is primarily used for Koodo and Telus but some have had success using it with Public Mobile porting issues. Please go to your inbox using this link to see the number as they don’t allow the number to be posted on the forums.
Alternatively, and according to Public Mobile CS Agents, since Public Mobile is a self serve service, they prefer you create a ticket. Here is a direct link on how to contact a CS Agent.
