porting error
MohammedMurad
hello, i ported my number from public to freedom, but my line got suspended today only. i havw $10 credit in my account. is there any way i can approve the porting request and use that credit. i still havent received any text for approval
popping
If you can login to your account and you have a $10 plan, click the reactivate current plan to get your phone working.
If you can login to your account and your current plan is over $15, add another $5 to your account and change your plan to the cheapest plan $15 and reactivate your account after plan change.
After you have a working phone, ask Freedom to port your PM phone number again.
when i spoke to the cust care they said that the community support can add the feature on your phone if you have credit and hence you can respond to the porting request
@MohammedMurad , when you refer to community support is it the moderator team.  The public portion of the community is frequented by customers at large helping each other.  If you want to get in touch with the moderator team, you need to click on the chat symbol on the lower right corner of the webpage an initiate a support ticket.
@MohammedMurad
Sorry, we are customers just like yourself.  We have no control over account issues.  Only moderators can help with that.
Don't understand your situation exactly.  Can you describe your situation in more detail?
MohammedMurad
HALIMACS
Hi @MohammedMurad
If you don't approve the text for the port out, Public Mobile should not allow the port.
Therefore, your Public Mobile account should remain active and you should be able to continue service as desired.
EDIT:  I should add, that if the port already occurred, then yes, your Public Mobile account would have deactivated.   In which case, you have forfeited any remaining account credit which might have once existed.   Sorry.
