plan has been changed?
danok
My account still shows the plan I am paying for but today I cannot access my voice mail or even call a local number.  The message keeps saying my plan does not include long distance which it does for 100  min per month.  But why can I not call even a local number or retrieve my VM????
2 REPLIES 2
popping
If your overage page is still showing you have not used all your 100 minutes, your account may not be provisioned correctly.  Add $1 to your account to trigger PM server to reprovision your account again.
I have a 100 outgoing minutes plan too.  The following is showing I had used 32 minutes out of my 100 minutes.  What is your minutes usage saying?  You had used all your minutes if you don't see this usage line.
  • Data & Add-OnsAmount Used
    100 Minutes Canada-Wide Talk
    32  /  100 MIN
GR
@danok did you use all your 100 outgoing minutes? Log in and look on the add ons to see if it shows xx/100.  If it's not they're it's all used up. You can purchase a 5$ 500 minute add on to keep talking. The add on will keep rolling over every month until used up
