plan change reward carry over
lessgrowth
I am considering changing from $10 to $15 plan. Do my present rewards: $2 for auto pay an $1 for loyalty carry over if I change?
10 REPLIES 10
Rubymangal
Yes I believe they do. Since the rewards are based on the account. Cheers!
@lessgrowth yes, even on the $15 plan it's throttled lte
@lessgrowth wrote:
What does "Any data will be 4G LTE throttled to 3mbps" mean to me with the $15/month plan?
And thanks for your support.
Less
This means that your data speeds, when connected to the LTE network, won't be any faster than that 3Mbps speed.
lessgrowth
Less
sunflowershine
@lessgrowth The reward will stay the same. As other mentioned that you can't get back the $10 plan in the future once you change your plan. I find buying an add-on of $5 of 500 minutes of Canada-wide calls are more feasible than having $5 more each cycle. The add-on minutes will stay in your account you use them up.
@lessgrowth
Keep in mind the $10 plan is no longer offered once you switch you can no longer switch back. Any data will be 4G LTE throttled to 3mbps.
ShawnC13
As stated all of your current rewards will carry over if you change plans.  The extra $5 between plans gives you a lot more service.  You will now have unlimited incoming calls, unlimited texting, and 100 minutes of outgoing calls!!
geopublic
@lessgrowth  Rewards and add-ons are associated with your account and not your plan so you can change plans as many times as you wish without affecting your rewards/add-ons.
gpixel
@lessgrowth hi yes they will carry over
Hi @lessgrowth ,
Yes, they do carry over!
