08-17-2020 08:50 PM - edited 01-05-2022 12:49 PM
I purchased $25 pin number entered not accepted.
I purchased $40 pin number entered by kids not accepted.
Each receipt for money says card activated so it appears to rang through ok your site not accepting. Purchaed 8/13th/20 due Aug 27/20 on P Mobile.
Help!
08-18-2020 01:08 AM - edited 08-18-2020 01:09 AM
Pay With A Payment Voucher dial 611 from your device.
If it's still an issue then submit a ticket to PM include the PIN numbers and ask them to add them into your account.
08-17-2020 08:57 PM
@tlkyle132 some vouchers take up to 24 hours to become active. The pin number is usually a 12 digit number on the receipt. Try entering them from within your self service account. Through either of these 2 places.
Or
If this fails take a snapshot of the 2 vouchers and contactt he moderators and ask them to add them for you.
There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-17-2020 08:54 PM - edited 08-17-2020 08:55 PM
@tlkyle132 wrote:I purchased $25 pin number entered not accepted.
Help!
@tlkyle132 hi have you tried by dialing *611? if yes then try in your self serve account if all else fails contact the moderators ask Simon the robot here to speak to a human to generate a ticket check envelope top right for a response they usually reply between 2-48 hours
