11-15-2016 05:06 PM - edited 01-04-2022 06:22 PM
Hi, i wanted to order a plan with public mobile, i was doing the transcation and i checked the box in order to keep my phone number with another company and it says that i need to communicate with public mobile community.. what do i do ?
11-15-2016 05:55 PM
it says i need to be authorized,how do i get authorization?
11-15-2016 05:47 PM
i have bought a plan with a different phone number as you suggested, now how do i change my phone number to the one i have with fido ?
11-15-2016 05:23 PM
DO NOT do that. Follow these suggestions please:
- if coming from Koodo do not use the same email address for Koodo and Public Mobile
- do not request the port-in during activation; take a temporary number, log out, confirm all services are active, log back into your account and select Transfer Number under Change Phone Number
- do not use any identifier except your account number EXACTLY as shown on your bill; it is the best item for any port-in request
- do not make any errors in the Authourized User; this must be EXACTLY as it appears on your bill
- do not use your number as the Alternate Number; use someone else's
- do not forget to click "I am authourized ...." BEFORE you entering your number (courtesy imm1304)
- do not cancel your account; that will happen automatically
11-15-2016 05:09 PM
fido
11-15-2016 05:08 PM
What provider are you currently porting in from?
