11-12-2019 12:04 PM - edited 01-05-2022 07:57 AM
how do i find out if my phone will be compatable to this system
Joining Public
11-12-2019 01:07 PM
You could check https://willmyphonework.net/.
11-12-2019 12:27 PM
You can check compatability by clicking GET STARTED at top of page and scroll down to PHONE COMPATIBILITY. Click there and follow instructions.
11-12-2019 12:22 PM
thank you so much
11-12-2019 12:17 PM
@DonnaCrocker most of the 3G,4G HSPA/ LTE phones that are compatible with these frequencies will work on Public Mobile. If your phone is locked to specific carrier, you’ll have to get it unlocked.
Phones compatible with Telus, Koodo, Bell, Virgin will work on Public Mobile network. All 3G, 4G phones from Rogers, Fido and ChatR are compatible and will work on the Public Mobile network.
To verify if you phone will work on Public Mobile network click
11-12-2019 12:05 PM - edited 11-12-2019 12:06 PM
@DonnaCrocker wrote:how do i find out if my phone will be compatable to this system
Click at top of page "Get started"
