4 hours ago
3 hours ago
yes from my previous providor sorry i hate techonology lol, but weird thing is i can make calls just cant receive and yes they are trying to fix it
3 hours ago
You mean from your previous provider? You'd need to repurchase another one then to receive the SMS. But support will guide you through it from here.
3 hours ago
thank you i am curretnly online with support i think i accidnetly deleted me esim on my phone
3 hours ago - last edited 3 hours ago
@giuseppegentile wrote:sorry what does that mean, i never got the text from my providor to port over number so incoming call are not coming in
Do you have the SIM from your previous provider on a different phone? If you are running 2 SIMs on the same phone, only 1 SIM can be set to receive text. Call the toll free number in the link below to see if your port is in the queue. If not, use the chat link in the lower right corner of the web page to initiate a support ticket.
3 hours ago
no did not close it still active
3 hours ago
yes just ported over today i can make calls just cant receive calls have an iphone and did esim
4 hours ago
Since you never got the sms then yea. Did you close the account prior to requesting to port? Account must be active to port.
You can message agents for assistance.
Or if you caanot log in, the other link below.
4 hours ago
Did you just join?
Try network reset.
Turn airplane mode, wait 1 minute, turn it off. Restart your phone.
Might need to do this several times.
For physical SIM card, if you have another phone, test it there for service.
4 hours ago
4 hours ago - last edited 4 hours ago
What is the make and model of your phone?
It requires VoLTE compliance for it to make and receive calls.
