phone plans
LEM5019
I noticed you have plans now that is cheaper than my for $19/month it shows 1gb on 4g  where mind has actually gone up since I have been with your company mind $25month 1gb 3g when I try to change my subscription to the $19/month on 4g it will not let me . I when with your company because it was the key word is was so my question is why can i not get the $19/month one.
funpig1
@LEM5019
I am currently on the $20 4G 3GB plan.
The $19 4G 1GB and $23 4G 6GB plan are currently available to me in my change subscription.  Also, the $29 5G 20GB plan is also available to me. These three plans are better than the new activation plans which are currently available for new customers.
I used to be on the same $25 3G 1GB plan as you and upgraded to a $29 4G 20 GB plan. I found that was too much data for my my needs. I just kept checking and downgrading whenever a cheaper and better plan became available for me.
All I can advise is to keep checking your change subscription and wait for a cheaper and better plan to become available.
You could port out and back in, but you will lose any accrued referrals or benefits.
Good Luck.
Chalupa_Batman
Sadly, the only way you can get that $19 plan @LEM5019 is to port out and port back in. Just know you'll lose any referrals you have if you have any.
TheSterlinger
Unfortunately,  Public Mobile has made that plan for new subscribers only. You can only change to plans within your account.
Sorry @LEM5019
you can only change plan to selected plans available on your Change Subscription page.  $19 is a pretty much a new activation plan and I don't think anyone can lower their plan to this one.
But check your Change Subscription page, it should have another $25 or $26 plan that gives you more data.  You might not be able to save money with the plan change, but you can get more data out of it
