07-26-2019 09:58 PM - edited 01-05-2022 06:07 AM
Hello, I was setting up my account for the first time and noticed the message to come to the forums if I wish to change my phone number. Since this was a former koodoo account or something along those lines... Anyways, the phone number I would like is REMOVED. My Koodoo account number is xxxxxxxx. The name under it is xxxxxxxxxx. Any help is greatly appreciated!
Edited by ShawnC to remove phone number
Edited by computergeek541: account number removed
07-26-2019 10:09 PM
@Allen1337 Welcome to Public Mobile!
First off, I would remove your Koodo info as this is a community forum so anyone can see it.
Second, if you are porting from a Koodo Postpaid account, you can port it yourself from Self-Serve. If you are prepaid, you can contact the moderators and give them your Koodo account info.
Link to contact moderators: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-26-2019 10:04 PM
@Allen1337 if it is post paid you can do that when you create your self serve account in change phone number good luck
07-26-2019 10:02 PM
@Allen1337 if you have a koodo pre paid account you will need a moderator click here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-26-2019 10:01 PM
@Allen1337 Hi you are on a public forum please use the 3 dots top right corner and edit your personal information
