01-02-2024 05:24 PM
I just switched from Virgin to Public Mobile, but my phone can only make phone calls to others now; when others try to call it, it says my number is not in service. How can i fix this?
01-02-2024 05:32 PM - edited 01-02-2024 05:34 PM
@rui1 I’ll send you the porting team number private message . They can give status update on the port or re trigger it if needed . If you still have issues here’s a direct link for support to further assist @rui1
send a private message To CS_Agents
