05-26-2022 04:30 PM - last edited on 05-26-2022 04:37 PM by computergeek541
My phone is not always ringing and it takes about a day to get a voice message. This happened about a month ago and changed some settings and as you can see this did not work.
05-26-2022 10:24 PM
@tech5 - hopefully this is temporary and will clear up on it's own. A good practice of restarting your phone regularly may clear up finicky issues.
Perhaps try performing a Reset of your device's Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
05-26-2022 05:41 PM
I would do a soft reset and make sure you are set on 3G not LTE.
Would you happen to be in a location with a weak signal?
05-26-2022 04:54 PM
Is this last month the first time you have had this issue? Are there any telus outages in your area. try the above steps for your network and that may assist.
05-26-2022 04:37 PM
@tech5 wrote:My phone is not always ringing and it takes about a day to get a voice message. This happened about a month ago and changed some settings and as you can see this did not work.
I am suspecting a network issue and am suspectting that there are difficulties siwtching from LTE to the HSPA network that is required for phone calls. Try setting your phone to HSPA only/3g onl/UMTS-only network mode.
