08-13-2025 05:03 PM
08-13-2025 09:02 PM
SMS usually is the easiest one to get it working as it works on both 3G and 4G .
Have you try Reset Network Settings ?
08-13-2025 08:57 PM
yes, I have tested my sim card with another phone, the sim card works on another phone. later, I changed settings on my phone, the data works, SMS not
08-13-2025 08:53 PM
@frank88 wrote:my phone is redme8, and it has all smartphone functions. I used this phone and the SIM for years. Before it worked very well
which city and province you are at?
First, Redme 8 is compatible with PM network on paper
While your phone is VoLTE capable, it is not on PM's VoLTE whitelist ( https://www.publicmobile.ca/en/on/get-help/articles/volte ) , hence it is using only 3G for voice
Telus is currently refarming the 850MHz band 5 spectrum and hence you are left with 1900MHz for voice calls.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
While one compatible band is still sufficent, reality is 1900 MHz could have less coverage, depending on your proximity to a tower and hence you are seeing a poor or no coverage with voice (Data is not impacted as your phone has the compatible bands on 4G/5G)
There is really nothing much you can do other than getting a phone that is on PM's own VoLTE whitelist.
08-13-2025 08:50 PM
08-13-2025 05:14 PM
This could be due to the decommission of the 850MHz 3G frequency. Older phones that doesn’t have the VoLTE settings will have issues.
Here is more information and scroll to the bottom of the link and enter the phone IMEI to see if your phone is compatible.
08-13-2025 05:05 PM - edited 08-13-2025 05:06 PM
What phone do you have? Data and SMS work?
Is today your plan renewal date?
Login My Account and confirm the account status
Reboot phone and Reset Network Settings . Test sim card with another phone if possible
