08-16-2021 07:15 PM - edited 01-06-2022 03:09 AM
08-16-2021 08:11 PM
@Anonymous
This is So--stupid it's like they are purposely spreading misinformation and copy&pasting CSA contact on purpose after I apologize!! So--So respectful! Max might coming out next month to prowl around the community!
08-16-2021 08:07 PM
Go to your settings>>connections>>mobile networks>>network mode>>3G only
This will work best for you but you can always test your connectivity in autoconnect 4GLTE/3G/2G but staying in 3G will prevent your phone from searching for mostly unavailable frequencies.
08-16-2021 08:03 PM - edited 08-16-2021 08:04 PM
If you HAVEN'T YET activated, try 'borrowing' someone else's SIM card who is currently using Public Mobile network and see what services work with the device you intend to use.
This way you can be certain before going through the activation process.
08-16-2021 08:02 PM - edited 08-16-2021 08:07 PM
@Ryl : Since the phone has little to no LTE, you might want to change the networks to any of WCDMA, UMTS, HSPA, 3G so that the phone isn't wasting energy trying to connect LTE.
Edit: @Ryl : The previous edit is in fact wrong if the device can't connect to LTE in the first place. So yet more confusion for you.
08-16-2021 07:57 PM
Do i need to change on settings
08-16-2021 07:33 PM
@Ryl : Looks like it would work for talk/text/data on "3G". But very little LTE.
08-16-2021 07:30 PM - edited 08-16-2021 07:30 PM
Your phone does not have bands 2 and 4 for LTE so it will not have 4G LTE service. So it will work but only with 3G services.
08-16-2021 07:27 PM
Public Mobile uses the following frequency bands:
08-16-2021 07:25 PM - edited 08-16-2021 07:33 PM
These are your specs....
Edit: since I can't copy and paste two things at once and pm's frequencies have already been supplied you need the 4G LTE bands 2 and 4 to be fully compatible as I posted below.
| echnology | GSM / HSPA / LTE |
| 2G bands | GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (Dual SIM model only) |
| 3G bands | HSDPA 850 / 900 / 1900 / 2100 |
| 4G bands | 1, 3, 7, 8, 20 |
08-16-2021 07:23 PM - edited 08-16-2021 07:31 PM
There are multiple models. You would need to make sure it is for the global market : JKM-LX1, JKM-LX2, or JKM-LX3.
08-16-2021 07:22 PM - edited 08-16-2021 07:23 PM
08-16-2021 07:19 PM
Hi,
I have a Huawei Y92019, it is not listed as compatible and wondering if it will work with Public Mobile.
thanks,
08-16-2021 07:17 PM
@Ryl : Before we can properly answer that we would want to know the exact make/model/submodel of the phone you're trying to use and what trouble you might be having.
