08-23-2019 05:48 PM - edited 01-05-2022 06:36 AM
When I checked compatibility my model and make of phone checked out. I failed to notice that the 4GLTE isn't I think. I signed up for a plan, now what do I do?
08-24-2019 11:10 PM
Are you having same issue ?
08-23-2019 07:46 PM
Thanks for your help. I have resolved the issue. It is working now. There was an issue with ow I installed my Sim card. I don't need much support because this is just for talk and text for my grandkds first phone.
08-23-2019 06:04 PM - edited 08-23-2019 06:06 PM
@mjholm wrote:It is a Huawei Y6 II
Huawei Y6II has limited support for Telus Network. You need to get a different phone to use with PM.
08-23-2019 06:00 PM
No it says emergency calls only
08-23-2019 05:59 PM
It lists it as compatible and I heard the 4G LTE is optional from someone else. Any ideas?
08-23-2019 05:52 PM
08-23-2019 05:51 PM
@mjholm wrote:When I checked compatibility my model and make of phone checked out. I failed to notice that the 4GLTE isn't I think. I signed up for a plan, now what do I do?
@mjholm LTE is technically optional. What's your phone's brand and model? (Please be as specific as possible with the model number)
08-23-2019 05:50 PM
What phone do you have?
If you phone does not work with PM, you need to get a phone which is compatible with PM.
There is no refrund since PM is a prepaid service.
08-23-2019 05:49 PM - edited 08-23-2019 06:26 PM
