phone calls
andy1818
Unable to make voice calls now. Nothing has changed on my subscription, texting works though
2 REPLIES 2
Dunkman
@andy1818
Which model phone are you using?  Is your phone VoLTE compatible with PM network? Are you a customer in Manitoba (3G network has been decommissioned in Manitoba)?
Check your IME:
https://www.publicmobile.ca/en/get-help/articles/volte
If not VoLTE compatible, that may explain your talk issues.
hairbag1
@andy1818
try rebooting your cell. Try a network re-set. Try your sim in diff cellphone (ignore that suggestion if you use esim)
Perhaps there could be a localized network outage.
