payment
tammylpatterson
I changed my billing address and now i can not make my payment
A1exander
Did you already try giving some time for the system to adjust the changes?
If you are still unable to make the payments with changed address, you can submit a ticket to a moderator as a specific concern.
Go to "Public mobile bot " bubble icon at the bottom right-hand corner and type "moderator". Next, click on Account-specific question.
Then from the replies, choose No, I need a human now.
Then click on the link to submit a ticket.
There you can put specific issue details and a moderator will get back to you.
Hope this helps.
NDesai
@tammylpatterson Were you able to add your CC with the correct address? Sometimes systems take a bit to update changes. Try using incognito/private browsing mode and see if that works.
 Did the self serve website accept the changes to your card/billing infromation?  I am thinking that you could be trying to make a payment with the billing informaiton as one address but the credit card company could be expecting the other address.
