09-29-2021 11:34 AM - edited 01-06-2022 03:39 AM
09-29-2021 06:48 PM
@RL368257 wrote:To reactivated me account and forget my personal question?
Do you still have services? If yes, this could be your account going through the normal renewal process.
The SELF SERVE account can say "expired" or "suspended" on the day of or before your plan is due to renew.
So if this is the case, ignore these messages on your SELF SERVE account.
If you have no services, and it is past your renewal, maybe your autopay failed?
Follow other's suggestions to get activated again.
If this was an Autopay failure, I would let the Customer Support Agents (CSA) know.
And, also ensure all rewards were or will be provided to you.
Methods to contact the Customer Support Agents (CSA): https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
09-29-2021 12:30 PM
you have to Contact Customer Support Agent by CS_Agent , and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck...
09-29-2021 11:57 AM - edited 09-29-2021 11:58 AM
If you can't use the Forgot my Password feature, you need to contact CS:
09-29-2021 11:51 AM
If your account was not activated for more than 90 days…your account is cancelled.
If less, just follow @Anonymous instructions.
09-29-2021 11:42 AM - edited 09-29-2021 11:53 AM
@RL368257 : When was the last payment made? You can use the 611 service and if you have a pre-registered payment card and your 4 digit PIN you can make a payment. Or buy a voucher in many stores or online and redeem it through the 611 service (no 4 digit PIN needed). Or you can use the Instant Top-up method in a few stores.
