07-10-2021 11:55 AM - edited 01-06-2022 02:46 AM
Hello,
I am trying to reset my password, but my email is locked out,so I can not reset by myself. Can you please help me access my account and help me reset my password.
Thank you,
Y-- H------
Edit by Dunkman: removed personal information
07-10-2021 12:03 PM
@yvon0215 if you need to open a ticket with mod to rest the password, you can try this to get to the ticket opening screen quicker:
at : https://publicmobile.ca/chatbot:
type: Fogot log in information
Click "Contact Us"
Click "Click her to submit a ticket"
There, you will be prompted to enter COMMUNITY Login (NOT My Account/Self-Serve) to validate your identity,
07-10-2021 12:01 PM
Hello @yvon0215
If your password reset does not work, you will need Moderator help.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
07-10-2021 12:01 PM
Sometimes you can wait another one hour and attempt to reset your password again.
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
If that does not work, you will need to contact moderator.
Click on the chat bubble icon on the right lower corner of website to start ticketing process to contact moderator. Type: I can't log in. Follow the prompts to submit ticket.
