09-13-2022
09:08 PM
09-13-2022
10:06 PM
computergeek541
could I open 2 account from same device ???? Thanks so much
Phones
09-14-2022 03:31 AM
Repetition from 6.5 hours ealier
09-13-2022 10:24 PM
Interesting product, here is the video on how it works:
09-13-2022 09:47 PM
@hTideGnow Nope, just me not reading properly! 😁
09-13-2022 09:45 PM
09-13-2022 09:34 PM - edited 09-13-2022 09:44 PM
Simore? Simon (chatbot) got a name change? 😊
edit: oops! should have re-read the post and looked at the link!
09-13-2022 09:26 PM
You can also try Simore multi SIM tray on any iPhone or Android phones.
09-13-2022 09:23 PM
HI @Halazakeya123- you meant the device able to answer calls for 2 numbers?
If you have a dual sim phone, dual physical sims, not 1 eSIM 1 physical, you can activate 2 sim card and put them both in the same phone
09-13-2022 09:10 PM
You can use 2 different sim cards connected to different accounts in one phone if it has a dual sim slot, yes @Halazakeya123-
Note, each account here at public mobile needs a unique email address. You cannot have more than one sim on one account. But you can use the same payment card for more than one account.
