12-09-2020 08:48 AM - edited 01-05-2022 04:25 PM
i have the old $10 plan that has no data.as part of the plan. yet i have been given, by pm,
a 1GB promo, plus now the holiday 2GB one time add on. can i use this data with my plan
and if not can i give the data to another member? thanks.
12-09-2020 09:41 AM
@aartmunn As long as your plan is active you can use any data add-ons just make sure data is turned on to be able to use it. If it doesn't work then make sure you have the correct APN settings on your device.
12-09-2020 08:53 AM
You can use the data add-on. You won't be able to transfer it. Also you would need to setup APN settings in order to use data.
Make sure you have the correct APN settings.
Tap - settings - network and internet - mobile network - advanced ( scroll down to ) - access point names
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
12-09-2020 08:50 AM - edited 12-09-2020 02:15 PM
@aartmunn wrote:i have the old $10 plan that has no data.as part of the plan. yet i have been given, by pm,
Yes, data add-ons can be used with plans without data. Sorry, but data cannot be transferred.
12-09-2020 08:50 AM
@aartmunn This is no different than if you were to purchase a data add on. It is yours to use when and where you see fit. Unfortunately you can't give it to anyone else.
