09-23-2019 09:23 AM - edited 01-05-2022 07:14 AM
09-23-2019 11:48 PM
A lot of people don't answer calls from unknown/blocked/private numbers. I know I don't answer them and I know most of the people I know don't answer them. If it's important then the caller will try again... from a proper number.
And most large businesses/organizations (along with many smaller ones) can subscribe to services which unblock and identify incoming callers. They pay good money (and the telecomms make good money) for technical/legal privileges which completely ignore user settings on consumer devices.
09-23-2019 11:10 AM
@geopublic wrote:@yogarajah62 Yes or no?
It's up to you -- On iPhone go to SETTINGS ----> PHONE ----> SHOW MY CALLER ID
and select if you want your caller id to show or not.
09-23-2019 09:46 AM
09-23-2019 09:36 AM
If you want to block calls on a cell, go into dialer settings and disable the option that displays your number, or enter #31# before dialing the number.
