not able to send or receive mms. pl. help
kish
hi not able to send or open mms. pl help. shut off voive mail can you remove for good. thanks
darlicious
@kish
Do you have your mobile data turned on?
Lovely2
@kish
MMS need to turn data on
@kish
If you have an iPhone, check your setting to see if MMS is enabled. Go to Settings>Messages>enable MMS messaging and also enable Send as SMS.
Turn off voicemail by dialing *004*8080000000#
