no phone service
05-08-2020 09:25 AM - edited 01-05-2022 10:42 AM
05-08-2020 03:10 PM - edited 05-08-2020 03:13 PM
@BusyBee Is it incoming, outgoing, or both that aren't working? If you're a brand new customer, I would also check that your phone is HSPA band 2/5 compatible. I've seen a few phones before that have LTE but no HSPA capabilities which is required for phone calls at Public Mobile.
05-08-2020 11:13 AM
@BusyBee Could you please give us more information? What does your self-service account says? What is your plan? How many mins and data you have for current cycle? Thanks.
05-08-2020 10:11 AM
@BusyBee wrote:no phone service but access to data ???
When was your last renewal date ? Could be your plan has expired but your using your home wifi instead of data.
05-08-2020 09:47 AM
@BusyBee as mentioned if data works and no calling (in or out ) it usually means you are on a limited calling plan and you have run out of minutes. are you sure data is working ie not on wifi?
if you are a new customer and ported a number out going calls will work, so that is not likley the issue, in this situation the more common issue might be an incompatible phone.
there might be other reasons for your issue, some added details are needed (phone model, new/existing customer, when did it stop working etc) so that the proper advice can be given, to solve your issue
05-08-2020 09:36 AM - edited 05-08-2020 09:37 AM
@BusyBee welcome to the community. Did you port your number? If its from another cell provider it can take up to 3 hours to complete. Stay safe.
05-08-2020 09:30 AM - edited 05-08-2020 09:52 AM
Which plan do you have ? If you are on the $15 plan then log into your account and if no minutes appear then you have used up your alotment. You could purchase an add-on for 500 minutes for $5. Try rebooting your phone.
05-08-2020 09:29 AM
@BusyBee what plan are you on? Have you used up your minutes?
Try turning your phone off and restarting it.
Check in your self serve account to make sure it says active.
How long have you had your plan?
