11-01-2016 07:44 PM - edited 01-04-2022 04:12 PM
11-15-2016 12:09 PM
Hi @bobarshi,
I'm really sorry you've been having issues with your port ![]()
I called our port team and they told me your port did not go through because you provided an IMEI that was invalid. Could you send me your Wind account number in a private message so I can resubmit the port?
Thank you!
11-15-2016 11:16 AM
@bobarshi please send a message to one of the moderators, with all the information mentioned in this thread - they'll be able to help you out. But be patient, as they are currently extremely overwhelmed with support requests.
11-15-2016 11:00 AM
11-02-2016 06:01 PM
Hey @stevezhu07
Please refer to my private messages 🙂
Mary
11-02-2016 05:57 PM
Hi @WearySky
The "don't do that" comment was mainly directed at the messaging anyone with a PM by their name... Agreed, if still not working then should get a moderator to look at it.
11-02-2016 03:04 PM
@JaK wrote:
No, don't do that. There are only a certain few PM staffers who's specific job it is to help with these type of issues, not everyone with a PM beside their name. I had already tagged one above, so they are already notified, you don't need to send them a message as well.
That's all covered in this posting: http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/All-you-need-to-know-about-our-Communit...
Well, they'll still need @stevezhu07's phone number, so a PM will be required at some point.
Having said that - 4 hours isn't at all uncommon for a port completion. I've heard of ports taking even longer. But if it's still not working now, a day later, there's definitely some issue.
11-01-2016 08:56 PM
11-01-2016 08:31 PM - edited 11-01-2016 08:51 PM
I ported around 3 hours ago and have the exact same issues with no incoming calls. Which moderator can assist me with this problem.
I have my old account number if that helps thanks.
**Please disregard message, I am getting incoming calls now thanks.
11-01-2016 08:25 PM
@Andy1000 wrote:Hi
Don't worry much about your Fido bill, they will only charge for the days your was still active, even if you paid your bill you will get a credit from them, unless you are on pay as you go.
in the main time you need to contact one of PM community staff to fix this for you, look for any user with PM beside the name and send a private message.
11-01-2016 08:15 PM
Hi
11-01-2016 08:11 PM
A moderator is still on for another hour tonight, hopefully they get to your issue. It not, they are back online 9 ET tomorrow morning, and will surely get to it then.
11-01-2016 08:07 PM
11-01-2016 07:56 PM
Hi @stevezhu07;
Sounds like a partially completed port, sometimes ports just take a bit longer. One of the moderators can take a look, see if they need to do something to move it along. @Mary_M, can you take a look?
Also, have you tried power cycling the phone? Sometimes that is needed to properly sync the sim.
