no data on iphone 6s
robertr
I just signed on public mobile and i do not get any data on my iphone 6s
will13am
@robertr, how about trying some of things from this web page.
https://support.apple.com/en-us/HT201415
RobertQc
What plan did you sign up for? Are you sure you have a data plan?
Is data enabled on your phone? Are you running a firewall? Do you have any data restrictions?
Can you put your sim in another phone to see if it works then?
@robertr
If checking the APN settings does not work, you may need to do network reset.
austinhuang
You can call/text?
If so, your APN settings aren't correct. See https://apn-canada.gishan.net/en/apn/public-mobile/apple-iphone-6s for the correct setup.
If this solves your question, please select my reply as Solution!
