09-23-2021 06:35 PM - edited 01-06-2022 03:37 AM
I checked the phone list but could not find the ALCATAL GOFLIP 3 Model no. 40520 FCC ID2ACCJN035. Previously my parents had an Easy phone. It too is not listed, but did function on public mobile. Will the ALCATAL GOFLIP 3 be a compatible phone?
Thank you
10-04-2021 12:51 AM
The Go Flip 3 supports HSPA and LTE with the same bands that PM uses, so you should be good to go.
09-23-2021 06:59 PM
@rjsdesign : The phone will work fine.
09-23-2021 06:50 PM - edited 09-23-2021 07:03 PM
Yes will working
Public Mobile uses the following frequency bands:
Good Luck
